Well, I checked out the17' 1979 GlasPly with the 1999 VolvoPenta 3.0GS engine and SX outdrive. I'd love your thoughts, anyone with experience, on what I found.
The boat sat in a garage for the last year and a half. Visually the engine and stern drive looked pretty good. Stern drive was elevated, and would not respond to the trim control. Troubleshooting, we bypassed the trim limiter box (approximate name...little thing on the transom near the trim pump, with a handful of LED lights on it) and got the outdrive to go up and down just fine. Might as well leave that little unit out of the loop permanently.
As soon as the drive went down, clean gear oil dripped from the forward side of the prop. Removed the gear oil fill plug, an the oil that came out was light mocha colored. LIght brown. Dipstick at the top of the drive showed totally clean oil up there. Confused about how the oil dripping from the prop shaft (seal?) could be so clean, while the milky stuff came out of the plug at the bottom of the drive, and clear oil was at the top at the dipstick. ???
We got the engine running without too much difficulty, considering how long it's sat. Oil looked clean. Sounded really good, idled well, jumped to life with the throttle. (Had the hose ears attached.) Did a compression test, got 137, 135, 142, and 118. #4 was more than 10% out. We wonder how terrible that is. We took it out for a sea trial. It ran and shifted beautifully, and I was amazed at its power.
Boy, I would sure love to hear from some of you experienced folk out there about whether to lean into this thing or walk away. Only $3000!
Thanks!
