I have a 97 Larson with a 4.3 GL. Boat ran fine in spring then started having issues.
1) For some reason at times after shutting the boat off on the water of after sitting on the trailer for a while I lose all power in the boat. trim will not work, radio, starter..Nada. Sometimes after disconnecting the battery and reconnecting power is restored. This is an intermittent problem.Made sure all cables are clean and good and cleaned ground to block.
2) all seemed to be fine yesterday (did all the general checks in the driveway, started it up on muffs, ran fine. Got to the lake, launched boat started right up, On my way back to pick up wife at dock engine started to sputter a little, then just died. Started the boat and would run for 10-15 seconds and then die at idle or half throttle.
3) Pulled the carb last night and there was plenty of fuel in the bowl.
3) I don't know if this is electrical or carb both. I am going to rebuild the carb since it has never had anything done to it in 20+ years..
Any other suggestions as to the intermittent loss of electrical power?
Thanks,
97Larson
Thanks,
97Larson
