aicmichael
- Jun 17, 2019
- 1
I have 2 questions:
One is where can I find the power steering actuator part number?
Second is how do I check the so called ball valves inside the actuator that regulate the fluid flowing into the actuator? In a different foru, someone had mentioned these ball valves could be bad, because I repaired my actuator with a rebuilt kit (purchased from Amazon for $40) and after the first use it is leaking again.
