Refitter58
- Jun 16, 2019
- 5
1996 volvo penta 4.3 GS PNCA, Outdrive SX-C1. 1.85
Bought a house and let the boat sit for over two years. Yes, I know better but. . . Here in sunny Florida I found rusty belt pulleys and frozen throttle plates. Bilge water had reached just below the harmonic balancer bolt. Seemed that the engine/rings may have been seized. Filled cylinders with MMO, half a bottle down the carb. Two weeks later still just slight movement. I bought the crankshaft rotation tool to put a little more pressure on the problem without snapping the bolt. Surprisingly it moved fairly easily. But what I found is that the steering wheel moves with the crankshaft rotation to the limit of the outdrive movement, left and right. Pulled the dipstick on top of the drive. It's not clean but full with no sign of water intrusion. Engine oil looks new. I had changed it just prior to parking/abandoning ship.
I don't understand the relationship between engine rotation and steering in these I/O boats.
