jaytintinger@q.com
- Nov 21, 2018
- 41
Converting a VP 5.7 gi to closed cooling. I let the doner motor go without taking the bypass hoses and fittings. Now I realise its to pump more water through the heat exchanger. On the old 5.0 the bypass hoses attached to the lower front of the exhaust manifolds to a "t", then to a pipe on the collar. The 5.7 feeds from the heat exchanger to the manifolds lower back on one side and the lower front on the other.
question?
where should the bypass hoses come from?
should there be any restrictors anywhere. or will it regulate itself.
question?
