PcolaBeach
- May 26, 2019
- 26
Is it possible to open up the ecm and check to see if one of the capacitors has a leak. Usually easy to see, the "legs" of the capacitor will be black from the leaking and sometimes the board itself will be stained in that area. Have you ever tried hotwiring the fuel pumps and trying to start it?
Thanks 89SM ... Do you happen to have a picture of what the capacitor legs would look like if they were leaking? We did jumper 30 - 87 with the fuel pump relay removed to run the fuel pumps. Engine cranked but did not start in this configuration.
