Ran fine last weekend. Now it cranks but won’t start. The engine typically deliver 2 loud beeps when turning to the on position, it no longer does that. I also do not hear the fuel pump prime. 50 amp breaker is good and I have continuity across it. Kill switch is good at the helm, have continuity across it as well. Pulled the plugs and harnesses at the back of the engine to check for corrosion, seeing no problems. Ground block at the back appears good. Loosened and tightened the grounds back down. Any help is appreciated.
