Daniel0321
- May 21, 2019
- 2
So I Have a aq225D with a 280 out dive everything is running fine but at (WOT) the boat will not move more than 6knts boat has no growth on the bottom / The boat is a bay liner 2450 Cier Flybige
There are many causes for low power, compression is low, to much or to little fuel, and others.
Is this a new to you boat, and if not when did the problem start?
What maintenance has been done, such as fuel filter, plugs, cap, rotor?
The lack of WOT list is found here
https://forums.iboats.com/forum/eng...6-list-of-possible-causes-of-low-wot?t=295070
