Hey guys, I have a 87 albemarle with a AQ271A Chevy 350. Everything runs fine but the coil is getting extremely hot to the touch. I just bough the boat and have not had it in the water yet. Afraid it may cut out after running it a while. I did find it was charging around 15.6 volts, found the Mando alternator was hooked up wrong. It is now charging 14.6 running. I have 12.6 on one side of the coil and 7 volts on the other. It has new a distributor that is electronic not points. Are these voltages on the coil normal? Do the coils run hot normal? Thanks
