Tanzersailor
- Feb 26, 2014
- 4
Hi all. I am getting a 44 ohms resistance between battery lugs (battery disconnected). I followed the trouble towards the trim/tilt area. Any idea what could cause this?
If you have a multimeter capable of measuring several amps you could introduce the meter between the disconnected negative terminal on the battery and the negative lead and check for draw on your battery. Depending on what boat/configuration you have, you could then begin removing components to see what component is causing your drain.
