We bought a 2011 Stingray 208LR with the V6 4.3 a few months back. It has the Volvo outdrive. Not sure which one but I can find out if you tell me were to look. The trim will work off and on. I've learned if i take a wrench or something metal and tap the pump housing, it will start working again. We'll ride around a while, and it won't work. A few taps, and its good to go. Since I know the housing is just that, and not the actual pump, I'm lost on what I need to do to fix it. Any help or advice would be greatly appreciated. I can post pictures or videos if that helps. The pump housing is the newer one with the 2 houses coming out of this side and 2 out of the top of the retainer clip.
