So I am a little paranoid about the castings, and worried about major issues I cannot see. Thinking of running water thru them and checking manifold passage for leaks.
I think the easiest way to do this is actually with them installed - albeit with the manifold loose on studs instead of being bolted tight to engine. My idea would be to hook the manifold water inlet to a garden hose, turn the hose on and let it run for 10 minutes or so forcing water thru the manifold and riser and out the exhaust passage.
Figured with the manifold loose, I would spot any leak either from the castings, or from sealing the riser to the manifold.
So, putting my paranoia aside, is this even worth doing - or does someone have a better idea???
