I needed new manifold and risers. I purchased the tall 11.3" risers and found OEM for those. I went with barr manifolds. The manifolds came in today and the mounting surfaces of the manifolds are painted. Some of the paint has come off already... looks like it was just chipped off or flaked off due to a poor paint job... no metal primer underneath or anything. My question is... should I grab some sand paper and a block and sand these down to bare metal? The surfaces on the OEM risers are bare metal and I know that it is important to have these machine flat. I can feel it with my fingernail that the surface is not even. If the gasket is to be put on dry that would lead me to believe that even a gasket sealant could cause leakage so why they would paint the surface is beyond me.
lastly, are the torque specs the same for the tall risers as they are for the standard?
Thanks.
Thanks.
