whitesharkseeker
- Nov 8, 2010
- 95
I have owned my 1996 boat with 5.7Gi engine and DP-S for 16 years and never had an overheat issue. Recently I had salt water in the gear oil so had a mechanic tear the outdrive down and found grooves in prop shaft where seal would sit allowing water in drive. Long story short, after getting shaft spray welded and ground to spec's, outdrive was assembled and put back on the boat. It now overheats when I throttle above 2,000 RPM's and at 3,000 RPM's temp goes to 210 degrees F. It heats up quickly barely a half mile out of the harbor but cools right back down at 1600 RPM's. I know the problem is with the drive, thermostat works and raw water pump is new. Any suggestions or advice? I read that drive ratio can cause those symptoms but makes no sense to me. Thank you.
Eric 22' Davis
Eric 22' Davis
