I have a 1994 Chaparral 2250SX Sport with a 8.2GL engine and a Volvo DPX outdrive. I am having a hard time finding a factory service manual for the outdrive.
Engine: 8.2GL PMDM Serial number 4110107171
Drive: Serial number 3102152403
Transom: Serial number 4111505486
All I am doing is changing the bellow on the drive but I would like to have the factory service manual for the outdrive too since I need to pull the upper gear housing off the outdrive. I did find the info in the adult only section about “Replacing bellows on 250 thru DP-E outdrives without removing outdrive” which is how I figured out that I did not have to remove the entire outdrive.
Do I have to buy a DPX manual from a dealer or can I download it form Boatinfo? I looked around on Boatinfo but I could not find a manual for the DPX.
I also looked on Volvo Penta’s website and could not find anything there either.
Thanks
Rich
Thanks
Rich
