Nomoneyz
- Mar 26, 2019
- 3
I recently came into this boat from my father in law. It's a 1973 trihull style with open bow. Has the volvo/penta I/O set up with a aq170 i6 and the 280 out drive. It's in decent shape and one owner. Has 550hrs. I did basic maintenance so far like oil change, spark plugs, rebuilt carbs, fuel filter and fresh fuel. Points look ok and are within spec. Had it running and was trying to tune the carbs because it had a bog and backfire when punching the throttle. Timing is in spec according to the sticker on the valve cover. Last time I shut it down to make adjustments to the linkage it wouldn't restart. I know I have fuel and air. I have checked for spark and am not getting any from the coil. The coil has 12v with key on. Not sure how exactly to test the coil further. I read through one sticky about diag and tried measuring resistances and disconnecting wires from the coil and trying for spark and nothing gave me spark. I'm leaning towards a dead coil but would like some opinions on this issue from some more experienced people. Thanks.
