Welcome Guest - Sign Up today
No announcement yet.
VP DP-S propeller shaft seal question
  • VP DP-S propeller shaft seal question
    After a nightmare experience pulling my main DP to change gear oil (had to use a prop puller) I noticed main prop shaft seal leaking gear oil near the bottom. Has anyone changed this type of seal without pulling the bearing carrier? I know that is the proper way but I hear the special tools are very expensive and hard to find. Any advice would be appreciated. Eric
    Also, I believe those seals were installed backwards. No milky gear oil so water isn't infiltrating lower end.
    Eric
    • #3
      you had problems pulling your prop because you are not doing your annual inspections and you did not grease the prop shaft like it says in the manual
      the bearing carrier needs to be pulled. there are back-to-back seals. the outer seal is the water seal, the inner seal is the oil seal.
      Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
      1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
      Past Boats
      1970 Wooster Hellion - Merc 9.8
      2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
      1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
      What’s behind you doesn’t matter.Enzo Ferrari
      • #4
        I believe you need spanner wrench Volvo Penta 3855877 to remove that retaining ring. I ordered one back in Dec still haven't received it. It is on back order from VP, no idea when it will come. No one seems to have it in stock.
        • #5
          Thank you gentlemen. I fear that I may have the same problem removing the bearing carrier as I did the prop and might bust it. I may just leave that job for the experts with the tools!
