What to look for in a used 290 dp?
No announcement yet.
tips on buying a used 290 dp
for your needs, a complete setup
preferably fresh water only
well maintained
low hours
keep in mind your looking at 30 year old drivesCheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
Past Boats
1970 Wooster Hellion - Merc 9.8
2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
What’s behind you doesn’t matter. – Enzo Ferrari
Although really well engineered drives, if not over engineered...they have one or two weak points.
The most common of which are;
water ingress through the bloody oil drain screw seal. I used to silicone over the plug after each oil change
The trim pump (if original) has a habit of passing at the valves inside the pump. This means the drive will slowly creep down, at best...and fall down at worst.
Check the stare of rhe cone clutch too, if you are able. Test by making sure it doesn’t slip or delay going in and out of gear after it’s warmed up and been running fast. These are a pain to do at best, and expensive to do, if by a dealer, at worst.
Oh and the pins you need to take out to remove the drive can be stubborn if not out annually.
ask Rick on the www.baylinerownersclub.org
or Ricardo on marine engine dot com
Same person, knows these inside and out.
I passed on a nice '89 Steigercraft Miami with a new crate engine because it had one of these. I always heard they were good but here in salt water mechanics don't like to work on old drives and especially ones where all the parts might not be available. I know from experience (OMC owner) its more difficult the older these things get. However I can still get good quality rebuild Cobra drives for a reasonable price. I wound up teaching myself to do the shift linkage adjustment that many mechanics won't touch. With the right tools and some patience it is easy.1988 Four Winns 200 Horizon
4.3 OMC Cobra
98 Jeep Grand Cherokee 4.0 Selectrac
07 Jeep Grand Cherokee Limited 5.7 Quadradrive II
"While air doesn't freeze....rust never sleeps"
iboats Boating Forum Directory
Over 100,000 Questions & Answers
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats (250+ Manufacturers)
Bayliner Boats
Sea Ray Boats
Zodiac Boats
