Welcome Guest - Sign Up today
No announcement yet.
DP-SM transom assembly electrical
  • DP-SM transom assembly electrical
    When I was redoing my transom the grommets and wiring got messed up that pass through the transom. I’m trying to order replacement wires. I found the trim sensor and grommet but I can’t figure out what the other wires were for(I’m not near my boat). It’s for the hole on the left though I believe. Check the picture. I thought it was for the anode corrosion system?
    Do you have the active corrosion unit at the base of the Transom Shield?
    Cranchi Ellipse 21
    5.0Gi (PWTR) 1999.
    DP-SM outdrive
    • #3
      Yes I do have the active corrosion! Thanks for the heads up! Let me see where I can find to order the wiring
