Hi guys, I haven't been here for a while but I know that when I need the guru's help this is the place!.
i need help trying to figure out what I need to do next. The boat is a 2002 Bayliner 2950 command bridge with the electronic shifter on both stations .we we're on our way back from fishing and went to the gas station to fill up. After we filled up the motor wouldn't start or even crank so we used the kicker to get back to the dock. The next day I opened up the control module for the shift and throttle control and it's a microcommander 585ce serial number ZB16620. I noticed the one of the four little timing belts had snapped. I ordered all four new ones and I replaced them. The boat starts and shifts just fine but it if I go over 2500rpm it starts to make like a white steam or smoke type so I stopped there and I really need some pointers. Any help will be greatly appreciated giys..it's fuel injected so I'm just guessing that it needs to be mapped or something..cheers.izzy
