Hi everybody Sorry if my english is not so good but, i am french and i need practice to get better. I have a 2000 Beneteau Flyer 701 with a VOLVO PENTA 4.3 GI PEFS engine. I am working on it for maintenance and fix problems and i have some issue with the cooling. My engine temperature gauge was not working anymore. I replaced it and also the two temperature sensors. Since then, I have a correct information on the manometer but, the warning light comes on when the engine is running (There is no audible alarm.) The diagnosis of the alarm gives an error 14 "engine coolant temperature sensor temperature low". The engine is working properly and all parameters are nominal. I only have this alarm light that comes on. Do you have an idea for this problem ? Thank for your help
