Welcome Guest - Sign Up today
No announcement yet.
Need some part numbers for 290A reinstall after transom rebuild
  • Need some part numbers for 290A reinstall after transom rebuild
    I know i want oem or oe replacement parts for the following
    bellows (both)
    raw water pick up goose neck
    raw water hose.
    Transom shield gasket (has silicone on it from factory any better suggestion?)
    o ring for y pipe
    sealing ring for bell housing
    Where the 2nd inside the transom shield goose neck attaches to at the power steering cooler, does this use a sealer as I didnt see an o ring?
    a link for a good parts break down site would help me with all this info.
    Thanks ahead of time.
    Google it and Volvo actually have exploded views with part numbers.
    Failimg that, look up the UK parts site keypart and type it in. They have a list of genuine and aftermarket parts.
    • #3
      Originally posted by dohcdelsol93 View Post
      A link for a good parts break down site would help me with all this info.
      What year is your setup?, Is there a serial number and/or product number on any of the drive and transom assembly tags?,
      http://www.volvopentastore.com/mall/...enta/help.html
      http://www.volvopentastore.com/Marin...view_id.765165
      Transmissions
      http://www.volvopentastore.com/Engin...--store_id.366
      OEM Quality Gear Lubes And Greases Available @ iboats.com 'By Bel-Ray Marine Lubricants -- BOAT SPECS -- FORUM GUIDELINES -- Volvo, OMC & Merc Stern Drive Technical Information For DIYers. -- OEM VOLVO PARTS POWERED BY iBOATS.COM -- All OEM Parts / Parts Lookup Now Available Through iboats.com --
      • #4
        use your mouse, click on the little shop icon in the upper left corner of your screen on the forum. click on boat motor parts, then go to volvo, then pick OEM volvo penta parts. from there, pick your correct motor and all sorts of lists with pictures come up.
        your boat would not have had silicone on the transom shield from the factory, it would have a transom shield gasket held in place by what is essentialy 3M weatherstriping adhesive.
        you need two of the drive sealing donuts
        the rubber flange seal for the PS cooler is there too.
        Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
        1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
        Past Boats
        1970 Wooster Hellion - Merc 9.8
        2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
        1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
        What’s behind you doesn’t matter.Enzo Ferrari
        • #5
          Im using a phone not a computer(cheap android at that) so a lot of things don't show up that would on a computer. The stuff on the transom shield felt like silicon! Should i go back with the 3m sealer or is something like beutle tape(spelling?) Better? Stuff has kept my sailboat windows leak free for years compared to the silicone they used from the factory.
          my boat is an 88, ill post up a serial bnumber tonight as engines/outdrives can be sevral years older than the boat hull they are found in.
          • #6
            No, get a new transom shield gasket....period. No shortcuts.
            you will use a dab of 4200 at the end where they butt together, by dab I mean the size of the toothpaste you put on your toothbrush in the morning
            Past Boats
            • #7
              I didn't mean a sealer in place of the transom seal, just to help it seal, looks like rubber cement in the shield and silicone on the transom side of the rubber.
              Are the 2 0 rings reusable or are they one time use?
