cwrhyne
- May 16, 2018
- 52
I was winterizing my boat yesterday and I found something that concerned me. While taking off the bottom hose off the raw water pump I noticed that where it connects it is a 2 piece deal and it swivels inside the upper piece. like its supposed to be glued in or something and it is not. like if I twisted it by with my hang I could pull it out. If you look at the picture, you can see almost like a fitting inside another. Should I be concerned? I looked at a replacement pump and they are one piece. So can this be fixed? Or is it even broken? Not sure whats going on here.
