Shaper79
- Mar 25, 2016
- 233
ok. Iv been dealing with this a while, 5.7 GSI Throttle body. It has the carter fuel cell with Low pump and Highpump. I have made sure pickup tube is clear , deleted anti “syphon valve for testing purposes “fuel line to fuel cell is clear, pulled fuel cell completely disassembled and cleaned out every spec of paint in the fuel cell. Order new pumps from the “mancave mechanic guy on utube “ pulled the pressure regulator on the throttle body and installed a new diaphragm checked stock spring and cleaned and reassembled. I do not know what stock spring psi is on the GSI5.7 marine motor. The truck motor 5.7 is about 9-12 psi fuel pressure from what I have read. Is the marine 5.7 the same? Idk. My fuel water separator is only installed last summer. Should be fine. “Volvo Penta Brand” this were it gets weird. My LP holds a perfect 8 psi of pressure no problems. But the HP at idle is at 28psi and when I reve it up it drops to 20psi then back to the 28psi. The spec for this is supposed to be 30psi and not lose psi under load. So what in the heck is going on here ! What else could it be. I’m checking psi directly off the pump head
