I recently had problems with my DP-A 290 Sterndrive. The gear oil was black, so I sent it to the place I bought it from for inspection. He said the cone clutch was slipping real bad and all the parts were blue from the heat. I gave him the ok to rebuild it and he recommend changing the lower unit to 1.95:1 gears. Not sure what the ratio was before. I was running A5 dup props and the acceleration and speed were ok. WOT was 3600 RPM.
Since I reinstalled it after rebuild, the acceleration is very slow with lots of black smoke until I get up on plane, then WOT speed is great at 30MPH and no smoke, RPM 3850. The turbo charger and precooler check good. I'm guessing there is too much load on the engine at low speed so I'm thinking about changing to an A3 or A4 props with less pitch, but WOT RPM will probably be too high. Engine placard says 3250 RPM. I would appreciate any suggestions!
