hodgenpodg
- Sep 27, 2017
- 9
I'm having an issue with my 2003 Volvo Penta 5.7 Gi-E and hoping I could gain some insight from users here as other posts have helped me a lot in the past (bad fuel pump at the beginning of the season).
I'll start with an issue that I started having about a two months ago just in case it might be related.
The engine was running perfect and would start up on the first try every time we went down. We did about a 1-1.5 hour drive and then anchored to have some lunch and swim (engine off for about 2 hours maybe less). When trying to start the engine I had the radio on loud and thought it started but it didn't (it may have started to turnover a little). I turned down the radio so I wouldn't stop cranking the engine till it was fully started and this time it wouldn't start (it would crank just fine). I thought maybe I just used the battery a little too much so i switched it to use both batteries and it still wouldn't start. I put the throttle in neutral and WOT and it finally started. (I looked this up and thought it could just be a leaky fuel injector and the engine was flooded and that was why putting the engine in clear flood mode worked but now I'm not sure). I replaced one of my older batteries (the other was already brand new) just in case but this same scenario happened the next three of four times we went out so I just kept thinking it was leaky warm fuel injector(s) and the clear flood mode kept working.
Two weeks ago I went down to go out and couldn't get the boat started at all. It would crank over nice and strong but just wouldn't start. I was going on vacation the next week so I didn't have time to diagnose but I was planning on replacing the fuse box as there is a service bulletin for that. I put the new fuse box on earlier this weekend and it still wouldn't start so I started finding all the different sensors (IAC, Crankshaft sensor, Camshaft sensor, TPS and others) so I would be familiar with their location when typing up this post. I did maybe slightly wiggle a few wires but didn't see anything in bad shape or exposed. Just before I was about to leave I decided to try it one more time and it fired right up and sounded great. I shut it off and let it rest multiple times and everytime it started right back up but I still had to get home. I went up this morning and it wouldn't start again. I tried a few things like putting in neutral and giving some throttle but nothing seemed to help it start but then seemingly randomly it started after maybe 10-15 tries and then would start fine every time after that.
My fuel pump is brand new so I don't think it is that but I am going to check fuel pressure on the rails next weekend. I also ordered a new distributor cap and rotor which I'm going to replace next week as well (I haven't had a friend to help me test spark at the distributor but its not a crazy amount of $$$ to replace the distributor cap and rotor so figured why not).
I'm wondering what other sensors would stop it from starting up so I could start to replace them and see if that helps.
Thank you.
Thank you.
