Salmonblaster
- Jun 14, 2018
- 8
Where to start. Went to go fishing, boatbstarted fine. went to back out of dock and engine died. what ive troubleshooted so far.
1. Boat is cranking over but wont fire
2. battery at 12.6 volts and i get +12v going into the distributor from the ignitor coil
3. using spark tester, i have spark from igniter coil to top of distributor and from distributor to spark plug and i have spark at the spark plug.
4. have fuel going into carb.
5. theres compression where i had the spark plug removed checking for spark and smell of fuel on cloth over hole.
im at a loss with fuel going to carb and have spark everywhere i should have. Could it be the spark is not enough to ignite the mixture.
