Hello,
First post here, hoping for some advice.
I have a 2000 Four Winns with the 5.7 Volvo Penta GSi PEFS. At idle after initial warm-up, the motor will run at around 160-170 degrees. As soon as the boat is underway at over 1000rpm, the temperature gradually drops to around 110 after a few minutes of cruising and will not get back up to 160 until the rpms drop below 1000 again. I have used an IR thermometer to verify that the gauge is accurate.
I recently replaced the thermostat and installed the 160 degree thermostat part # 3856961 (OEM VP). This did not fix the issue.
I searched iBoats and found a thread referencing the bypass valve being obstructed with chunks of impeller; I checked the thermostat housing including the 90 degree bypass elbow for obstructions and did not find anything. I have also recently replaced the impeller and there were no missing vanes.
What should I check next?!
Thank you.
Thank you.
