And I am back. Had the boat out on the weekend and it appears (what I assume is the outdrive) has developed a grumble around 2000-2500 RPM. At lower RPMs it is quiet once I get on plain around 2800-3000 RPM it sounds fine. It's _just_ in the 2000-2500 RPM range.
I was thinking maybe u joints but I would assume they would be loud at any RPM. It doesn't seem to be worsse when the drive is turned, likewise it still makes the noise when perfectly straight so I think that rules out gimbal.
Any thoughts on what could be the issue?
Thanks in advance all!
