As already mentioned, you have spark at the coil tower, so ignition is working ok as to modules, reluctors, etc.
Spark from the coil tower hits the middle of the rotor from the distributor cap center terminal. Are the cap and rotor the correct parts? Are you sure the rotor is installed correctly? Does the distributor cap inside center terminal have the spring loaded graphite ball intact? The components may not be as I am describing, but there has to be continuity from the coil wire into the distributor cap, into the rotor and out to the spark plug terminals on the cap. If the parts are not correct then they may have been damaged when installed.
