What's the priming procedure after replacing
S Salmonblaster Cadet Joined Jun 14, 2018 Messages 8 Aug 30, 2018 #1 What's the priming procedure after replacing
alldodge Moderator Staff member Joined Mar 8, 2009 Messages 40,741 Aug 30, 2018 #2 should not need priming with a GL (carb motor). If the filter is full it will do the rest when you crank
