USA_boater
- Jul 31, 2018
- 275
When draining the engine, besides the exhaust manifold and block brass drain plugs, where else to drain and what hoses if any to disconnect? I recall from another thread someone saying a plug the thermostat housing? where else?
ALSO, I was shopping flush/winterize kits on amazon and someone warned in the reviews that the kits with the 5 gallon container to add the pink antifreeze were not right for vovlo's unless you had some other adapter that of course wasn't linked to. The reviewer warned that using the kit and pink stuff could still crack the block unless you had some additional special knowledge and adapter for the volvos...I only wanted to use the pink stuff to inhibit further corrosion since my boats cooling system is very corroded.Should I forget the pink stuff or what?
I DO plan to buy the kit anyway just to use for flushing the system with some salt/scale remover chemical (probably the starbrite stuff). Perhaps I should just flush the scale with chemical at the end of the season and drain system and call it good? Or can anyone tell me how to SAFELY use the pink stuff on the Volvo Pentas?
I ahve a 4.3GL-C and it has the flush adapter in the engine compartment. I wonder if I should use that or the lower unit water pick-ups with muffs to do any flushing or winterizing so the stuff goes up through the entire system? For running on the trailer I prefer the cooling port in the engine compartment over using muffs just for convenience, but I do have muffs if needed.
