1995 Four Winn, 200 Horizon, 5.0 litre (Ford block I Believe) model 502APHUE OMC Cobra (this info on valve cover) This was about the time Volvo Penta and OMC merged.... I have a Volvo Penta SX Cobra Outdrive and says OMC Cobra on engine valve cover sticker.
I installed a new thermostat on Aug 10, Aug 14 went for a ride, gauge read a needle pointer above 150 f mark, so about 152 to 155 f at 3000 to 3200 rpm. Even with a 4200 rpm stayed about the same. About a hour down and a stop and an hour home all was exact same. Went out Aug 19, about 3000 to 3200 rpm about hour down the gauge was exact same as before. On way home it ran 139 to 142 f, same rpm..... at marina while I idle to get to launch dock it went to 150 f.
This is a new thermostat, o ring retainer, and gasket. Why would I get this sudden change in temperature? I can only think maybe a bit of debris got picked up at the marina I stopped at? I think there was 6 or 7 feet water at that dock.
Any Ideas why the temp would change. Maybe next run it will clear itself as it is on the trailer at home, and engine has completely cooled?
The boat is in showroom condition hopefully phots from marina I stopped at on Aug 19, 2018 are in my photos
https://www.iboats.com/ideabook/ron3033-photos
Thanks
ron3033
Thanks
ron3033
