1984 volva penta aq125a with Bosch distributor 0-231-178-017.
Run fine with standard 3ohm 12v coil, points and condenser. Have also recently ensured timing belt is lined up correctly.
Ehen i I put in the Ignitor II 92842 with Flamethrower II 0.6ohm or previous coil I need to turn the distributor as far as I can counter clockwise before it will catch and run for a few seconds.
I double checked the the ground and power tests, ensured the black wire goes to the negative coil post and the red wire goes to the positive coil post. Have also ensure the gap is set correctly.
I wouldnt have expected to move the distributor at all to change the timing.
Has as anyone had a similar experience?
