New to the forum, Hello!
This year has been tough with mechanical issues, I usually manage to fix these things myself, but this issue has me stumped..... The issue is that when in water the boat will not shift into forward drive. Reverse is no problem, but forward is hit or miss, and it seems to only shift when increasing the rpms.....
Out of the water the drive shifts forward/reverse without issue, but I realize that is not a good indicator since there's no resistants on the drive. I did notice that when shifted in reverse (engine off) the prop will not turn forward, however in forward gear (engine off) the prop will turn in reverse, not sure what this means......
The shift cable is ok. Tested with someone shifting, while I had the drive cover off watching the shift lever change from forward, neutral, reverse, no issue there. However, I will likely change the cable anyway as it's a little stiff.
After researching the forums, I'm starting to fear it's the cone clutch....=(
In addition to the shifting issue: I have noticed sever loss of bottom end power. The boat takes forever to plane. This year I have changed: spark plugs, distributor cap, rotor, and drained the fuel tanks replacing with fresh fuel. Still not solved.....
BOAT INFORMATION:
1998 Wellcraft Coastal 210
Volvo Penta SX-M Drive
Any idea?
BOAT INFORMATION:
Any idea?
