I have a 1997 Volvo Penta it is TBI
5.7GIPLKDCE, SERIAL NUMBER 4110144111, PRODUCT NUMBER 3868623
This is a recent purchase. It sat for 2 years.
I cannot locate the warning horn/alarm anywhere and it never sounds. It is not under the dash, on the engine or in the controls. Any ideas?
I removed the fuel and cleaned the fuel tank.
I put new gas in and tested the motor.
It ran poorly. Backfired through the TBI and exhaust and stalled under load.
I replaced plugs, wires, cap rotor and water pump based on condition, age and symptoms.
Compression is 180 to 195 in all cylinders.
Spark test shows good spark.
Fuel pressure test [HP] shows 15lbs.
It starts and runs very well at idle up to about 1300rpms under load then back fires thru the TBI.
It immediately cleans up and runs very well up to 4000rpms for approximately 30 seconds. The motor then dies. The fuel pressure and voltage appear good throughout the rpm range under load.
The engine will restart but immediately stalls. If I wait 5 to 10 minutes it will restart and run at idle up to 1200rpms, under load. It will run this way without incident.
The temperature is good both on the gauge and at the thermostat.
What should the temp on the exhaust manifolds be?
I am going to pull codes tomorrow.
Any ideas about what else I should be looking for?
