After this season is over/ I plan on changing my intake to the raw water pump to a southbay thru hull and closing off the inlet from the outdrive. I feel I would get better flow this way and not have to keep worrying about air infiltrating.
Anyone with any thoughts.
Also will this create a cooling problem for the outdrive oil. I've read mercs need to be cooled but not volvos.
2005 5.7 gle fresh water cooled with heat exchanger and dp-sm outdrive
