RussWalters
- Jun 25, 2018
- 34
I will be replacing my Risers/Manifolds shortly on my VP 5.0 GL-E. My question is, is there anything in particular I should be inspecting as part of this process to see if anything else is going on? On my Starboard riser, there is definitely some rust streaks on the outside that makes me believe there is some leaking going on, and that riser is much hotter than the port one. I'm wanting to make sure there is not other serious damage that has been cause in the head unit.
Engine is running fine, although has some issues cold starting sometimes and idles a little rough when first warming up.
Thanks!
RW
Thanks!
RW
