Skidude17
- Jul 10, 2014
- 225
I have a 19' Glasply with an AQ150 engine and AQ270 drive. I'm pulling the engine...again...due to an oil leak that I believe is coming from the oil pan gasket.
To the point, I found fresh oil in my drive bellows. I assume this is coming from the outdrive, but would like some more insight. Does this mean I need to have my upper gear unit rebuilt?
I have spare outdrives, but they don't have the right gear ratio. Would it be easier just to swap the upper gear unit? What are the implications of changing the upper gear?
