Folks - need a little help with finding an exploded drawing with part numbers for DP-SM transom shield, year is 2004.
Cannot find an exploded parts diagram, and have seen on several vendors sites where it states SX transom shield parts are not compatible with a duo-prop.
In particular, I want to replace the water hose, nipple o-ring, bellows, and upper unit to transom shield gasket. Just want to make sure I am ordering the right things.
I did find an exploded view of the upper unit on marinepartseurope, just cannot locate the transom shield. Figured the SX-M would probably be the same, but again no exploded view on transom shield.
Any clues greatly appreciated.
Scott
Scott
