Ok, so here is an odd one for you. Boat has run great for 3 weeks, with zero electrical issues ever. Gauges were worn so we decided to replace them. Wife was wiring the new oil px gauge back together and accidentally crossed wires. It should have two ground (black) on the center post, and two positive (purple) on the batt post. She instead somehow put one of each on each post. When we went to op test the gauges she mentioned she might have put the wires on backwards and couldn't remember where they were originally. Assuming she didn't cross the colors without looking at them, I started the engine just to see an oil rise or not. There was an immediate rise on the gauge so I shut the engine off. HERE'S WHERE IT GOES SOUTH! The engine would NOT turn off! The key was literally off and removed from the ignition! Still running. I panicked because I had not planned on running the engine longer than 5 seconds, and was no where near water. I finally got the thing to shut off by shorting the positive and negative posts on the back of the oil gauge. Whew!
HOWEVER, now, after discovering her error, and correcting it, the key does nothing. Normally you get beeps after the key is turned on....nothing. Key turned to start does nothing. Found a 2A fuse blown, replaced that. All other visible/easy to see CBs and fuses are good. Still won't turn on. All the power on the panel including backlights, horn, wiper, nav lights, etc, all work perfect. Including the backlight for the oil px gauge.
WHAT DID I FRY????? Thanks in advance for the help.
Volvo Penta 8.1L GI on a 2006 2765 Regal Commodore
