herring627
- Mar 9, 2018
- 24
See pics...how bad is it? What if I continue to run it? What would you do?
Back story: Boat was running well until it overheated. Did not know anything about boats then after a $500 Sea Tow I started to wise up. Impeller was completely shredded, (only bits were found!), this and the thermostat were replaced. Took the boat out and warning buzzer went off after 5 min. (this time I had enough since to kill the engine and bring it back in under cooler temperatures). Have yet to pressure test it, maybe a leak? Notice a lot of rust buildup around the manifold. Took that part off...oh oh, rusted walls and surfaces ... replaced manifold and now...these valve stem thingings - not good, not good at all. I think I may be over my head, but then again, what is there to loose if the damage has been done?
This is a Volvo Penta 5.0 GXI. Have the manual and am learning... Thank you for any advise and wise counsel you can offer. This is my first forum post ever and look forward to the response.
