hi guys, So I rebuilt the top end on my 5.7 gsi. I put everything back together and when i went to fire the motor to adjust timing my fuel pumps didn't click on for 2 sec like they normally do prior to the rebuild..
So digging into the fuel pump relay I think I have found some problems....
Testing the ground 85 I don't have a ground with the key on or off.
Testing 86 I have power with the key on and off
Should 86 only be on when the key is on?
I ran a ground from the backside of the relay to the batt and the fuel pumps kick on and stay on.....
Im pulling my hair out on how this works... what to try to trouble shoot and why this all of a sudden happened...
I have tried to troubleshoot it per clymers manual but I haven't gotten any where....
I pulled and cleaned where the wiring harness grounds to the block and all of my components have ground minus the fuel pump relay on 85
I added a new alternator, could something here be the culprit?
Any and all comments are greatly appreciated..
thanks dustin
thanks dustin
