I have a 2005 Chris Craft with twin 5.7Gi-Ef's with approximately 300 hours. The starboard engine has been starting hard for a few months now. Around Thanksgiving I pulled the batteries and tested one at AutoZone. Sure enough it wasn't making full amperage. I replaced all 3 batteries and the boat fired right up.
Fast forward a couple of months later and I am having the issue again. I noticed the voltage for the port engine is always around 14 volts prior to starting, but the starboard is 10 volts. I tried every possible position of the battery switches and it doesn't move from 10. On Sunday I physically moved the batteries and got the same voltage of 10v, but it did start.
Once it's started the voltage does jump to 14. What could be causing the low voltage prior to start, and could this low voltage be part of my hard starting issues?
