northernterritory
- Sep 4, 2017
- 69
Hey guys,
I’m rebuilding the Holley 2300 that is on my Volvo 3.0. I have a few questions.
1. The instructions say to “turn the idle limiter caps to its leanest position and remove the cap. Observe and record the initial position of the needle slot. Turn the needs until lightly seated, record the number of turns required to seat the needles. This procedure is necessary to reinstall the needles after rendering.
***I am not sure what this is referring to. Could you shed some light? Also, if I have already disassembled this part, what should I do?
2. I am unable to get the pump check ball out. The check ball weight is out. Am I missing something?
3. Do I need to disassemble anything on the throttle body?
4. How do you recommend I remove gasket residue? A stainless steel brush on my drimel?
5. I didn’t see any of these parts when I disassembled (see picture below). Any idea what they go to?
6. What should I soak the parts in, for how long, and what solvent should I use to get the cleaner off?
