5.7 gi fuel injected. When the key is turned to cycle the fuel pumps it pushes gas in one side of the throttle body through a small metal line then stops after it puts a good bit of fuel. Then I turn the key to crank the boat and get even more fuel out of the same metal line and floods out the engine. I just replaced both low and high pressure pumps along with the relay.
Help
Help
