northernterritory
- Sep 4, 2017
- 69
I had the cylinder heads off a GM 4cyl iron block marine engine worked by a machine shop. I am now ready to install it. I have a Fel-Pro head gasket and have cleaned the top of the block really well. What else do I need to do to properly reinstall the head?
Should I do any cleaning of the bolt holes?
What about the head bolts, they have quite a bit of white goop stuff on them. Does that need to be cleaned off?
What type of sealer should I put on the head bolts?
Any other tips?
Any other tips?
