I want too change my gear oil and not sure of flat head size or socket size. too remove so I can drop gear oil ? . . DO NOT WANT TOO STRIP
Removed duo props ( have tool ) Removed plastic cover with the 3 screws . .
I see the vent screw but did not attempt too open until I find right flat head for oil removal
TWIN lower units on a 2003 DUO DRIVE Volvo Penta .
Checked fluid levels full , dirty , no water on dip stick .
. I am in Fl and use all season
I have assorted flat heads but non fit , too big or just a hair too small , METRIC ?
I had shop change last season and just got boat back from new engines installs
Figuring I will do gear oil change
thanks as usual .
thanks as usual .
