Last winter I failed to properly winterize my boat. Doesn't typically get cold where I live but last winter was unusually cold. I went to prep my boat for it's first outing and noticed water shoot out of my manifolds. After some inspection, I noticed the cylinder heads were cracked as well. The oil was milky. So I purchased new cylinder heads and exhaust manifolds. I lapped the valves, did valve lash adjustment and tested compression. Cylinders 2,4,6, and 5 tested at 175psi and cylinders 1&3 were at 165psi and 170psi. I drained oil and added new oil. Idled boat for 5 minutes and drained oil again. I took the boat to the lake and idled around for about 20 minutes, shutting it down every 5 minutes to check oil level. After everything appeared ok, I ran it up to full speed and it ran great for about 5 minutes and then it shut down. The risers were hot and I noticed the gasket was leaking between riser and manifold. I installed new gasket set and have now decided to pressure test block. I capped hoses going to manifolds and disconnected coolant hose at outdrive where I pressure tested block. Pressure drops immediately and sounds like air is escaping thru riser as I can hear it at outdrive exhaust piping. Am I doing something wrong or is this an indication the riser is bad?
Thanks
Thanks
