Chuckberg2
- Aug 15, 2015
- 14
Hello, thanks in advance for any help or advice
Have a 2003 VP 5.0 GXI B with 326 hours Ran good Thursday would start and stall on Friday, pumped throttle it threw an alarm code Map sensor 34 (Rinda Techmate) scan tool and it would stay running, not correctly but would idle all day. My first thought was fuel relay so changed that , no joy, Tested the map sensor and tested good, added New anti siphon valve, Fuel filter, pressure tested fuel 8 pounds low side 55 high side during priming and running and held 55 pounds high side when shut off, Changed IAC valve (shot in the dark) disconnected TPS pulled a low voltage code and audible alarm but it idled until Connected it back up and it shut the engine down, Disconnected batteries for 30 minutes and hooked back up.Tested every ground I could find, cleaned up made sure tight, checked J1 and J2 pins for continuity to ground and we are all good there, relays are getting the power they should be. the trim switch at the helm was shorted out, fixed that, added a new cap and rotor.
When the system goes into default mode due to a faulty sensor, does anyone know what other sensors are put into default mode to allow engine to run, just so i can narrow down how many I have to check? been after this a while, got the schematics and the service manual downloaded but keep going round in circles, only codes I am getting are self made to get the engine to idle so I could maybe diagnose with scan tool.
thanks
thanks
